johncameron
Message 1 of 3
Why remove posts?
I've had my post regarding usage monitoring removed. I'll try again, why can't this be up to the minute?, currently I'm advised of usage levels from two days ago. How do I prevent an accidental slip over my limit?
2 REPLIES 2
jac_95
Guru
Guru
Message 2 of 3
Re: Why remove posts?
johncameron
Your previous post was moved to here: https://community.bt.com/t5/Bills-Packages/Monitoring-my-usage/m-p/1398771
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
johncameron
Message 3 of 3
You're right.. my bad..
