Message 1 of 6
Why take away 4th ethernet port on new smart hub?
Why swap the 4th ethernet port with a WAN port, what use is that what do I do with the WAN port, leave it empty?
5 REPLIES 5
Message 2 of 6
Re: Why take away 4th ethernet port on new smart hub?
Hi @NevUK   The latest smart hub 2 has a setting to allocate the 4th Ethernet port as WAN or Ethernet port.
Home -> Advanced settings -> Broadband -> Full Fibre (FTTP) Mode.
Message 3 of 6
The only time you should have a home hub with a dedicated WAN port (coloured red) is if you have FTTP which requires a WAN port. Otherwise as @@VeteranISPUser says, the 4th port is dual purpose
Message 4 of 6
Thanks for reply, please explain dual purpose.
Message 5 of 6
LAN/WAN
Message 6 of 6
Thanks for your help
