wiggle987
Message 1 of 2
Wi Fi Connection Drops Out At Specific Times For Long Durations - Redux
So a few weeks ago I posted this topic because my wi-fi would randomly cut out, none of the solutions appeared to be doing anything but after annother week it started working fine again, fast forward until last week when we had a power cut and now the problem is persisting again, I found out last night that it may have been a firmware problem (with the homehub ui not allowing you to select whether wireless connections are visible or not and it just says "yes") and that a reset would solve the problem, and it worked fine throughout last night and most of today but now it's cut out again, the wireless connections option is stuck on "yes" again and the firmware is up to date. My question is whether it's possible to stop the home hub from updating it's firmware, as it's pretty frustrating having to do a reset every day!
1 REPLY 1
Message 2 of 2
Re: Wi Fi Connection Drops Out At Specific Times For Long Durations - Redux
hi no it is not possible to stop it updating its firmware
