Message 1 of 4
Wi-Fi Disk will not pair with BT Smart Hub
I have tried to setup the BT Wi-Fi disk with my BT Smart Hub - Type A.
I have tried normal connection, ethernet and WPS with resetting to factory defaults.
Does this disk work with BT Smart Hub Type A or does anyone have any other ideas.
Many Thanks
3 REPLIES 3
Message 2 of 4
Re: Wi-Fi Disk will not pair with BT Smart Hub
@RonHutcheson
What colour disk is it?
If its a white one, then it has to be physically connected to the home hub all of the time, so you need more than one to get any advantage.
If its a black one, then that only works with the Smart Hub 2.
Message 3 of 4
Hi Keith
Its a black one. I thought that was the case. Many Thanks
Message 4 of 4
@RonHutcheson wrote:
Hi Keith
It looks like you may have bought the wrong one.
