ManxCat
Message 1 of 20
WiFi Keeps Stopping Working
Hi, I just go this new Laptop from HP, and it works fine for about a hour and then I can't access any websites and I have to click the WiFi icon on the bottom right then reconnect and then it works fine again.
I have been through a load of diagnostics with HP online spport and there looks to be nothing wrong with the Laptop.
Has anyone else here had this intermittent WiFi connection fault?
19 REPLIES 19
imjolly
Message 2 of 20
Re: WiFi Keeps Stopping Working
which hub do you use?  if hh4/5 then make sure
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
ManxCat
Message 3 of 20
Thanks, but I just tried to get into the home hub and it was the same problem, it coudn't even load the login screen for the home hub.
Does this shed some light on where the issue lies?
ManxCat
Message 4 of 20
Also its HH 3.0 so I can't find those settings.
Keith_Beddoe
Message 5 of 20
Try a factory reset of the home hub 3.
ManxCat
Message 6 of 20
Ok thanks, just tried that lets hope it works.
imjolly
Message 7 of 20
as you are using a separate modem with the hh3 all the stats are in the modem and the hh3 does not have smart setup or 5ghz network
ManxCat
Message 8 of 20
It just happened again after doing the factory reset.
Chrome says there is no internet connection, but my WiFi icon in the bottom right says I am connected.
imjolly
Message 9 of 20
you are connecting to your home network and not BTWIFI/FON?
ManxCat
Message 10 of 20
It says I am connected to BtHub3-WS92. It just says "open" below the BTWiFi.
