ManxCat
Message 11 of 20
Re: WiFi Keeps Stopping Working
SO it just happened again.
When my laptop could not connect I tried my phone and made sure the data connection was truned off and it worked fine.
Then I had to disconnect from the WiFi icon to get my Laptop back online.
Please does anyone know what the problem is, its so annoying.
gg30340
Message 12 of 20
If your phone is staying connected to the Homehub it would appear that the problem is with the laptop.
If you click on the wifi icon and then go to "Open Network & Sharing" then "Change adaptor settings" then click on your "wireless connection" and then click on "Properties".
This should bring up a new window. Click on "Configure" then "Power Management". If the box " Allow computer to turn off etc" is ticked, untick it. Click OK.
ManxCat
Message 13 of 20
Thanks a lot but I've already been though the power management thing.
gg30340
Message 14 of 20
Are you able to take it to a friend/relatives house and connect to their router? That will at least rule out or in the problem being either your laptop or the Homehub.
ManxCat
Message 15 of 20
I have just done a factory reset of my new Laptop, so far so good.
Could be something I installed on it that caused it.
gg30340
Message 16 of 20
It could have been the Network Card driver that was causing the problem and factory resetting the laptop will have restored it. What operating system does the laptop have? Has it been updated to Windows 10?
What did you install that makes you think it caused your problem. Hopefully it wasn't BTDesktop Help.
ManxCat
Message 17 of 20
It is a brand new HP ultrabook which came with Windows 10, since resetting its been fine for the past few hours so could have solved it.
I rekon it could have been some SEO software that caused it but not really sure.
gg30340
Message 18 of 20
As long as it's working now.
ManxCat
Message 19 of 20
It just did it again, the fan seemed to be working hard and it felt hot near the cpu so I think it might have been overheating as I had it on my bed.
imjolly
Message 20 of 20
 Probably blocking the vents for air circulation sitting on your bed in soft covers
