Message 1 of 7
WiFi calling
Hi,
I am moving an Sony Xperia E5 (2017)  onto BT mobile from another network.
Sony tell me that it may need a BT firmware update to enable WiFi calling.
Does anyone know if that is a) necessary ; b) possible?
cheers
Alan
6 REPLIES 6
Message 2 of 7
Re: WiFi calling
you will need to change your network settings to BT and then see if wifi calling activates and works for you
Message 3 of 7
Re: WiFi calling
Hi,
my question is really about what can be done, if anything, if WiFi calling doesnt present as an option if and when I plug in the new SIM.
Sony tell me that the phone itself is capeable of WiFi calling if the specialised network-specific phone firmware is fitted. They suggested that I contact my network of choice to see if any relevent firmware is necessary and if so can be retrofitted.
WiFi Calling is important to me as the BT/EE network signal is too weak for use in my house, whereas Vodaphone is fine. I would prefer to go with BT as I have BT Broadband and Halo so would like to maximise on the economy of scale.
Any advice gratefully received!
cheers
Alan
Message 4 of 7
Re: WiFi calling
It's usually just a case of insert the sim, get connected to the network and then see if you can enable it via the handset menu.
I don't think there's a way to specifically download a BT firmware update onto the phone, so hopefully it will work for you straight away.
Message 5 of 7
Re: WiFi calling
From the net:
Sony Xperia X, XA, X Compact, XZ, XZ Premium:
  1. connect your phone to WiFi.
  2. from the home screen, tap the Apps icon.
  3. tap Settings.
  4. tap More.
  5. tap Wi-Fi Calling.
  6. set the Wi-Fi Calling toggle switch to On.
you can switch Wi-Fi Calling off by switching the toggle to off.
This thread seems to confirm it is a "goer"
https://community.bt.com/t5/BT-Mobile/BT-Mobile-WiFi-Calling-Sony-Xperia-5-II/m-p/2108709
Message 6 of 7
Re: WiFi calling
Hi,
The phone is an Xperia E5, not a Xperia 5-II: I believe they are quite differerent phones but I could be wrong.
Message 7 of 7
Re: WiFi calling
Because of the age of the phone (launched with Android 6)  Wi-Fi calling was not baked in to Android at that point and was only present as a network specific addition to the OS.
