Message 1 of 4
WiFi disk setup issue
So, it was setup for months no issue. Suddenly I lost connection and the light was flashing indicating WPS mode.
I factory reset and fllow d setup procedure. After factory reset I had a red light -> connect ethernet -> sold blue after around 5mins-> disconnected ethernet and wait for solid blue.....this never happens, after 10mins.
I have two other disk that work fine
3 REPLIES 3
Message 2 of 4
Re: WiFi disk setup issue
Now it's started flashing red, then resumed flashing blue. I presume this means it's can't connect via WIFI/WPS
Message 3 of 4
Are the discs coloured black or white, as there are two separate wifi systems?
Message 4 of 4
They're black. There are two other disks and they're working just fine. I'm referring to the third disk, that lost connection and now can't be setup
