Peter19
Message 1 of 12
WiFi for Kobo
I have just purchased a Kobo e-book reader and it seems that I am able to use it to download books anywhere using a WiFi connection.
Can anyone who has a similar device please give me any tips as being elderly I think it may be a bit over my head.
Thank you in advance for any help.
Peter.
Swansea.
11 REPLIES 11
Message 2 of 12
Re: WiFi for Kobo
Do you have BT Broadband at home?
Message 3 of 12
Re: WiFi for Kobo
do you have bt broadband with a wireless hub?  if so if you go to wifi on the kobo it should show available networks.  select your network ssid and when you try and connect it will ask for wifi password which is normally on your hub.  just enter and it should connect
Peter19
Message 4 of 12
Re: WiFi for Kobo
I am a BTInternet Customer and have a Home Hub.
I have tried to connect using the Kobo Guide but all of the sites available in the area have a padlock on them and I have to log in apparently.
I have just registered with the BT WiFi service and hope this will help.
Peter.
Swansea.
Message 5 of 12
Re: WiFi for Kobo
Can you connect the device to your own home hub ?
Peter19
Message 6 of 12
Re: WiFi for Kobo
I am not so much worried about being at home Keith I am thinking more of when I am travelling and was to download a new book.
Peter.
Swansea.
Message 7 of 12
Re: WiFi for Kobo
when you look at networks available can you see your own hub ssid and also that of BTFON and BTOPENZONE?
Message 8 of 12
Re: WiFi for Kobo
Provided that your book reader has a web browser, then you should be able to use any wireless network which has one of the following names. These will not have a lock symbol next to them
BT FON
BT Openzone
BT wifi
The reason being, is that when you connect to any of the above, you will have to login to the home page, using your primary e-mail address and password.
I have a Kindle, and it prompts me to enter my details when I want to connect to any of the above.
Peter19
Message 9 of 12
Re: WiFi for Kobo
Thank you both so much for your help.  Hopefully alll will be OK.
Peter.
Swansea.
Message 10 of 12
Re: WiFi for Kobo
any problem then come back as there is always someone around to help you
