Message 1 of 4
WiFi not working but speed test result is good
My speed test result is 70mb/s from my Bt infinity hub when running the Bt test. However, I cannot open the App Store on my iPhone 6 or send pictures unless I turn off WiFi and use mobile data. My link to my work computer dropped part way through but this mostly works ok. Can anyone help? Thanks
3 REPLIES 3
Message 2 of 4
Re: WiFi not working but speed test result is good
Message 3 of 4
Which hub are using. Can you post stats
Anonymous
Not applicable
Message 4 of 4
Another possibility if you're using a smarthub is to turn Authoritative DHCP off (Advanced>My Network >IPv4 configuration).
Maybe its just my hub or devices but I've found that Authoritative DHCP can cause contention between the hub and the device
