Message 1 of 18
WiFi problems with HomeHub 3
Since recently joining BT broadband with HomeHub 3 I am experiencing background hiss on my cordless phone and my Epson Stylus Photo PX720WD only responds intermittently.  A mesage on the printer indicated excellent signal strength but a network blockage.  What is wrong?  How do I fix it?
DS
17 REPLIES 17
Message 2 of 18
Re: WiFi problems with HomeHub 3
Try using the onscreen display on printer and setting up wireless again as it should connect without a problem - good printer
Message 3 of 18
Tried set up again and report says network working correctly but a "router/access point channel conflict has been detected". Any clues?
Message 4 of 18
have you got the printer on a fixed ip address?
Message 5 of 18
Don't know the answer to that one....
Message 6 of 18
if you go to printer onscreen display then to setup (spanner) then network settings, confirm network setting then obtain ip address - manual or auto?
Message 7 of 18
That's set to AUTO
Message 8 of 18
so if you look through that heading does it show your hub ssid and that it is connected?  did you enter new password when you got hub?
Message 9 of 18
Yes, the Hub SSID is connected and I am using the original password.
I have also tried changing channels as I am getting interference on the cordless phone; am currently up to channel 7 with no improvement in either printer or phone interference
Message 10 of 18
if your printer is connected to your home network then can you see it in 'devices and printers' assuming windows
