Message 11 of 18
Re: WiFi problems with HomeHub 3
It's Mac but I can see it in the mac equivalent.
Message 12 of 18
is it ready for use - windows shows green tick on mine
Message 13 of 18
At the moment I can print but the scanner won't work.
Message 14 of 18
so printer on the network and you can print so as far as networing the printer and HH everything is working.  problem is with the MAC not scanning so I would re-install driver from epson website
Message 15 of 18
OK. Worth a try but it all worked well with the SKY router. Only encountered problems since changing to BT.
Message 16 of 18
but if printing wifi then printer is conencted to your home network suggesting to do with MAC/printer and not the HH
Message 17 of 18
That's the snag. Printer sometimes OK, scanner less so but works occasionally.
Message 18 of 18
I would re-install the software on your mac as you may well need a driver update.  The fact that it does work suggests network ok and problem is MAC to printer
does your printer show wifi connected with symbol and green bar in top RH corner
