JaguarLover101
Message 1081 of 1,144
Re: Wifi Calling
Wifi Calling on my Samsung S7 Edge was killed by the 1st July Update, however with todays update it has now been reinstated along with VoLTE on BTU!
johna56
Message 1082 of 1,144
Re: Wifi Calling
Last software upgrade brought Wifi calling back before replacement SIM arrived, so don't know if new simm would have helped
John
tintin
Message 1083 of 1,144
Re: Wifi Calling
Can I ask how you managed to get this working on an S7. I am trying and contacted BT but no luck!
JaguarLover101
Message 1084 of 1,144
Re: Wifi Calling
Which CSC are you on, dial *#1234# and post what it says under CSC
tintin
Message 1085 of 1,144
Re: Wifi Calling
Hi.
It says G930FTEF2ERH1
JaguarLover101
Message 1086 of 1,144
Re: Wifi Calling
Your phone is O2 branded since it says TEF (ex contract presumably) unfortunately there's no way to access Wi-Fi calling without flashing either the genetic firmware (BTU) or the EE firmware (EVR)
tintin
Message 1087 of 1,144
Re: Wifi Calling
Thanks very much for this information. I cam completely new to flashing firmware. Is this something that is relatively straightforward and worthwhile, or a high possibility of screwing up?
JaguarLover101
Message 1088 of 1,144
Re: Wifi Calling
I did it on my phone initially, I changed from the generic to EE (and flashed it back), it's relatively painless, you put the phone into download mode, run 'Odin on your pc, click a button and it's off. There is a chance things can go wrong, the first time I tried the flash failed and I was greeted with a warning message on the phone saying it was corrupted, fortunately I was able to flash it again and it worked, another risk is although it shouldn't, it could 'trip' Knox and stop apps like Secure folder and Samsung pay from working, this didn't happen to me but some people have said it happened to them. If you are switching to BTU firmware, one large benefit will be that updates are more recent and frequent since they come from Samsung instead of via a carrier and of course you will have access to Wi-Fi calling and VoLTE. Any questions let me know
Dean007
Recognised Expert
Message 1089 of 1,144
Re: Wifi Calling
Hi @tintin
Flashing a handset is something you should only do if you are confident in doing so, if you do go down this route ensure that you back up any data on your handset. Also BT do not gaurantee that the service will work even if you flash the device.
Retrovertigo
Message 1090 of 1,144
Re: Wifi Calling
I have just bought a Nokia 7 plus, and despite some teething troubles with BT, wi-fi calling is working just fine.
It is labelled as an android one phone, so has the latest android version.
