Hi
Ive got an unusual error with my home wifi - it will no longer connect to the icloud? Apple have checked everything and its not their end - as when i turn off wifi on the phones and connect to 4G it connects without issue.
My hub and broadband is working without any other issue as im working from home on various websites - connected all over wifi. its just the icloud it doesnt like and keep stating there is an issue
Apple have tested everything and say its def not their end - and as I can connect via 4g demonstrates its not an icloud issue
Trouble is to back up the cloud - you need need to be connected to wifi - so im stuck.
Any ideas - ive rebooted the hub etc and still nothing
kind regards
Solved! Go to Solution.
Check that BT Web Protect or BT parental controls have not been activated, as they can block some sites.
Thank you it was the parental controls
