A strange one.
I have both WiFi and LAN connections to my HH3 for different computers
The LAN connection is always fine - good speed, no drop-outs, etc
The WiFi connection however is a nightmare. It works for a few hours and then the computer drops the internet connection.
It is not the WiFi connection to the HH3 as I can still get to the HH3 web page but any internet address gets a "DNS not found" error.
In this state, the LAN connection still works fine. I can browse the Internet fine just not from a WiFi connection.
The only solution is to reset the HH3 fully (a disconnect/reconnect of the internet connection doesn't help)
Any ideas?
Chris
@ticklos wrote:A strange one.
Any ideas?
Chris
Hi there,
It sounds like you need to change the wireless channel on your HH3.
If you're on Windows then you're going to need inssider 2 or if you're using a Mac, then you'll need to download istumbler
Download whichever one of those is appropriate to your OS and do a scan for wireless networks close to you and you will be able to see which networks are operating on which channels and change to a less congested channel, if need be 🙂
I hope this info helps 😄
I would also check for driver updates, do not trust Microsoft update to give you the most recent ones!
I have same problem with my HH2. Wifi will die whilst streaming bbc iplayer I have to restart the hub to get it working again. I believe loads of people have this problem with the wifi, Im thinking about scrapping the bt hub for a 3rd party router.
Thanks all for the suggestions.
I did the SSID check and noticed something strange.
I had BT FON enabled which was broadcasting (as BT FON and BT OpenZone) on channel 11
My private connection was on channel 6
Channel 11 was also being used by a neighbour - but I always connected to the private connection so that shouldn't have mattered.
I have now disabled BT FON so I will just have the one SSID connection. In the HH3 advertising blurb, it makes a big deal about searching for free channels so you don't get interference!
Chris
