Are you 100% sure that it is only the wireless that is dropping out?
If you are sure it is only the wireless and not your broadband connection, the engineer changing the master socket or Customer Services "refreshing" your line, what ever that was, will have no effect on the wireless signal.
If it is only the wireless signal does it drop out on all your wireless devices or does it only affect some of them and if so which ones?
