Message 1 of 7
Wifi extend 200m to link surveillance camera
I want to set up battery surveillance camera and door bell/intercom on my halo wifi network that is approx 200m away with trees in line of sight and and incline of 25%.
How do I get the wifi to reach tonthis point?
6 REPLIES 6
Message 2 of 7
Re: Wifi extend 200m to link surveillance camera
@mcan
You would have difficulty with normal wifi at that distance.
Can you run an external Ethernet cable to that point, if you can, then a wireless access point with POE injection would be the best option.
Message 3 of 7
Not a chance in getting WiFi to work over 200 metres.
Ethernet won't work at 200 metres either.
Message 4 of 7
@mcan
Is there any mains supply at the far end?
The only other option would be a mobile broadband router with an unlimited data package.
Message 5 of 7
Hi
Thanks for your response, No mains at the other end, so looking at solar charged camera
Message 6 of 7
How about an Arlo Go camera, add a sim and cheap data package and then you have a simple security camera.
it’s battery operated but also is able to connect up to a solar panel.
Message 7 of 7
You could look at something along these lines: Wi-Fi Kit for Up to 500m Network Extension for Offices, Out-houses and sheds. (just one example) alternatively try looking up Pringles Can attennae (attennas) for a cheaper DIY option.
Depending on what hardware you have and how much power available attaching an attenna might be a challenge.
