Ngeorge10
Message 1 of 2
Wifi keeps dropping
Hi. I have bt hub 3.0.
Connected to approx 10 items (sky tv,iPad,iPhones etc). Wifi keeps dropping.
Is there anything I can do to prevent this ? Thx
1 REPLY 1
Keith_Beddoe
Message 2 of 2
Re: Wifi keeps dropping
Welcome to this user forum.
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
If that fails to fix the problem
Its more likely to be wireless interference, as this is a very common problem. You can try all of the 13 wireless channels to see if there is any improvement. You need to turn smart wireless off to do that. Smart wireless only has a choice of three channels.
