Qazqaz
Message 1 of 3
Wifi keeps dropping
I have a BT Business Hub 5.
Recently the wifi keeps dropping out. Also when trying to reconnect it often doesnt recognise the pword/authentication.
All the time the blue light on the front stays on.
Im guessing its a router issue but can anyone confirm.
New router from BT? Buy an independent one? Or is there a fix on what I have already?
Any help gratefully received as Im getting severe grief off the kids and missus !!!!
2 REPLIES 2
licquorice
Message 2 of 3
Re: Wifi keeps dropping
You could try a factory reset of the hub by pressing the recessed button with a pin for 20 seconds. Next to try is changing wireless channel. If that all fails, dump the hub and buy a decent third party router.
Devon_Dave
Distinguished Guru
Message 3 of 3
Suggest you dump the homehub. I have same issue with my hub 5.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
