Nawach
Message 1 of 8
Wifi micro cuts
Hello everyone,
I've been confronted to Wifi (micro) cuts for a month or so, with the connection to my BT hub going on and off constantly (sometimes it can be every 2 hours, every half hour or every 2 minutes, depending on the day and time).
This is the first time that the situation has got this bad in the 3 years I've been using a Wifi connection.
This morning, I installed a Wifi channels scanner which confirmed what I thought: my private hub has become also a "BTopenzone" relay, an option which is now apparently "by default" for every BT Broadband customers, unless you opt-out.
I'm trying to determine if the fact of being a "relay" could cause my current problem with my private Wifi connection.
Thanks in advance for your replies.
7 REPLIES 7
john46
Message 2 of 8
Re: Wifi micro cuts
it should cause no problems at all if your hub is going on and off it is more likely a faulty hub
Nawach
Message 3 of 8
Re: Wifi micro cuts
Hello John,
Thanks for your reply.
The hub does not go on and off itself. However, the wifi connection is.
I have a couple of other PCs connected to it via USB and Ethernet, and the internet connection is faultless as far as they are concerned.
Keith_Beddoe
Message 4 of 8
Re: Wifi micro cuts
Which home hub do you have?
Nawach
Message 5 of 8
Re: Wifi micro cuts
1.5, I believe...
verkosh
Message 6 of 8
Re: Wifi micro cuts
A 1.5 is really old it may be best to try and get a new hub from BT I think they are around £49 as your a bt customer but if you ring the sales team you may be able to get a free one and cheaper broadband if you agree to a new contract
Nawach
Message 7 of 8
Re: Wifi micro cuts
Problem solved by changing the Wifi channel, via the BT Desktop Help app. It's been 2 weeks and everything's good.
john46
Message 8 of 8
Re: Wifi micro cuts
glad all is working ok now
