Message 1 of 4
Wifi router compatibility with both FTTC and FTTP
Hi
I currently use BT’s FTTC and have:
- Huawei EchoLife HG612 modem (BT supplied)
- Netgear Nighthawk R7000 (AC1900) wifi router.
I want to upgrade to a new router soon. However, FTTP may be coming to my area within the next year so I’d like any wifi router that I get now to be also compatible with FTTP.
What do I need to look for on the specs of any new router to ensure that it is compatible with both my existing FTTC and future FTTP?
Thanks.
3 REPLIES 3
Message 2 of 4
Re: Wifi router compatibility with both FTTC and FTTP
Your current Nighthawk router is compatable. Any router with a WAN port will be.
As for specs, it depends on your needs.
Message 3 of 4
Thanks for the reply.
I read somewhere that the WAN port has to red. Is that just for BT routers and not 3rd party ones?
Message 4 of 4
The WAN port is red to distinguish it from LAN ports, electrons don't care what colour it is.
