phil_the
Message 1 of 9
Will new people get our phone number after we move?
There are lots of questions from people wanting to know if they can keep their old number when they move. I know we can't as we're moving out of the area. What I would like to know though is will the new people moving into our house get our old phone number if they don't request a new one? If so, can we request that this doesn't happen?
phil
8 REPLIES 8
DavidM
Moderator
Moderator
Message 2 of 9
Re: Will new people get our phone number after we move?
Hi @phil_the and welcome.
The numbers are owned by Openreach. Once your line stops the number goes back into a pool to be used on another order. The likelihood of it being used at the same property is tiny so you shouldn't have anything to worry about.
Cheers
David
phil_the
Message 3 of 9
OK thanks
TelephoneBob
Expert
Message 4 of 9
Openreach don't own the numbers.
phil_the
Message 5 of 9
https://www.birchills.net/birchillsblog/who-owns-phone-numbers.html
It would appear no-one 'owns' the numbers but OfCom are ultimately responsible for managing them, not OpenReach.
DavidM
Moderator
Moderator
Message 6 of 9
I stand corrected @phil_the and @TelephoneBob.
Cheers
David
phil_the
Message 7 of 9
No problem David. Thanks for answering the question 🙂
Hwalter
Message 8 of 9
Sorry, it meant we want to swap the number of landline 1 over to landline 2. Thanks.
Hwalter
Message 9 of 9
Thanks, I don't know how this forum works but just need some guidance. I can't believe it can be impossible just to swap a number over. I should have added that both landlines are BT.
