topleya
Message 1 of 9
Will this replacement modem/router work with Infinity?
Hi,
After spending hours trying to port forward on a Hub 5 Type A on BT Infinity, numerous calls, emails & tweets, I have given up with it ever working.
I have since discovered that a bug in Home Hubs that has existed since Home Hub 3 is causing the port forwarding to not take effect no matter what I do.
So my question is, will this modem/router
TP-Link TD-W8980 N600 Wireless Dual Band Gigabit ADSL2+ Modem Router for phone line connections (2 UBS Ports for Storage Sharing, Media/Print Server, IPv6)
work with BT Infinity
I want to be able to remove the Home Hub 5 entirely and use this.
Thanks in advance
8 REPLIES 8
legitimise_sailing
Distinguished Expert
Message 2 of 9
Re: Will this replacement router work with Infinity?
Not without a modem
To say thanks for a helpful answer, please click the white star
topleya
Message 3 of 9
It is a modem/router not a router
legitimise_sailing
Message 4 of 9
Infinity is VDSL2 not ADSL2+ so it needs a VDSL2 modem.
topleya
Message 5 of 9
Ah **bleep**
Cannot find anything to replace the home hub until I can change ISP (stuck in 18month contract)
legitimise_sailing
Message 6 of 9
You could buy a HG612 v3B modem from an auction site for a few quid.
topleya
Message 7 of 9
Nice suggestion, but it's just adding to the cost.
I'm actually stuck behind an unchangeable moderate NAT setting until I can leave BT.
I'm gutted as the speeds are incredible and reliable, but the router has a major bug that BT seem to be ignoring.
Shame really
legitimise_sailing
Message 8 of 9
Try ringing BT and asking for a modem then. The engineers still carry them on the van as other ISPs can't use the HH5.
topleya
Message 9 of 9
I will give this a try. Thanks
