Message 11 of 24
Re: Win 10 HP Laptop Continually Disconnects from BT Smart Hub 2
Thanks, I have tried this and it hasn't resolved the problem
Message 12 of 24
You may get some information of activity from Windows Device Manager. (Type "Device Manager" in bottom search panel).
You will see details of CPU usage, Disc, Memory and wi-fi. It also lists the running processes.
This may give you more clues.
Message 13 of 24
Do you mean the task manager? I've looked into that and the device manager and haven't found any clues, starting to lose the will to live...
Message 14 of 24
Hold the Win Key down whilst pressing R.
Type cmd into the Run box which opens.
Type ipconfig /all (note the space, it won't wok without it) into the Command Prompt window
What does it report for IP address, DNS server & Gateway
Message 15 of 24
Seems that you know all the answers. Can’t help you any more.
Do you still hold a warranty/service contract?
Your suppliers told you that it’s too old!
Message 16 of 24
What make and model of laptop are you using?
When you say you have updated drivers, did you go onto the laptop and network card manufacture's websites to check for the latest drivers rather than using Windows update?
Message 17 of 24
Ribblelancs I certainly don't have all the answers but I have already tried what you suggested, thanks for the advice.
gg30340 It's a HP Pavilion13-s052sa, and no I couldn't find any drivers other than the ones through windows update, which claims the drivers are up to date.
Message 18 of 24
Message 19 of 24
There's nothing wrong with that, your ethernet connection to the hub is good
Could you unplug the ethernet cable and do the same test again with a Wi-Fi connection
Message 20 of 24
Just checked that link and it seems I already have the most recent driver.
I've just noticed on my screenshot that the wi-fi was disconnected when I took the screenshot - this must have been one of the disconnects as I was using both ethernet and wi-fi at the time. I've attached another screenshot with the ethernet unplugged.
