ParaJack
Message 1 of 9
Wire from wooden post?
Hi, the wire that comes from the wooden post - across the road - to the top of the house and then down the wall and in through the wall to the master socket. Is that one long wire, or is it joined from when it hits the house and drops down?
Thanks 🙂
8 REPLIES 8
pippincp
Sage
Message 2 of 9
Re: Wire from wooden post?
There may be a junction. It may be better if you explain why you ask.
Ectophile
Distinguished Guru
Message 3 of 9
Nobody knows without looking.  It can certainly be one long wire.  But BT junction boxes are also common where lines have been altered over the years.
Icarus
Message 4 of 9
A direct line from the DP to the NTE is preferred, less joints less things to go wrong. Although sometimes it is necessary to connect the drop wire to the lead in via a joint.
An outside joint would either be an Above Ground Dropwire Closure (looks like a black sausage). A BT66, grey box about 5 inches long and 3 inches tall or a BT16, about 3 inch squared and comes in a variety of colours.
Then there might be an internal joint box, most commonly a BT76 or BT80.
ParaJack
Message 5 of 9
OK thanks guys.
I'm asking as if all goes well Infinty is being installed tomorrow (Friday), I wish the wire coming into the house to go from outside stright through the bedroom wall and to a new master socket on that outside wall, rather than the current setup where it goes into the hall (miles away from the PC), looking outside it looks like there will need to be a bit more length on the wire for it to reach the bedroom. Is it something that can be extended with ease?
Thanks 🙂
Deathtrap3000
Recognised Expert
Message 6 of 9
If you get an engineer who knows what they are doing, yes its a simple job. You may get resistance from the engineer if they are inexperienced or unwilling to go the extra mile for you. Generally contractors fit this description.
ParaJack
Message 7 of 9
I'm going to start off with "Hi mate, do you except bacon butties and hot chocolate as bribes?" lol 🙂
The email I received today confirming the appointment mentioned "Your BT Infinity engineer", would it still say that if it was a contractor?
Thanks 🙂
john46
Message 8 of 9
No it is a standard email it is the luck of the draw who you get
ParaJack
Message 9 of 9
Well thought I'd post a quick update: The bribes worked Smiley Very Happy, he got his bacon butties and hot tea, I got my new master socket where I wanted it 🙂
Thanks 🙂
