luke_y2k
Message 1 of 3
Wired Ethernet Connection form PC or DVR to Home Hub 5 - Straight through or Cross over wires
Hello
I have a question regarding Wired Ethernet Connection form PC or DVR to Home Hub 5, do you need to run Straight through or Cross over the wires in the cat 6 / cat 5 cable ?
Regards
Luke
2 REPLIES 2
gg30340
Message 2 of 3
Re: Wired Ethernet Connection form PC or DVR to Home Hub 5 - Straight through or Cross over wires
Straight through although if you use a crossover cable it will auto sense and still connect. Cat5e is sufficient.
luke_y2k
Message 3 of 3
cheers , my networking is a little rusty
