monkeybutler
Message 1 of 3
Wireless Access Point Help (Netgear WG103)
Hi All
Don't know if anyone can help me here, but I've recently been given a Netgear WG103 Wireless Access Point, in the hope that it will improve the poor wireless range in and around my house.  I've already done a walking test with a WiFi app on my smart phone, and now where my dead spots are.
I changed the IP address on my LAN card in my PC, connected to the Netgear, did a complete reset, upgraded the firmware, and then went through the user guide.  I eventually managed to see the Netgear on both my laptop's wireless card, and on my iPad.  However neither would connect.  In the end i went through the guide a few times over a couple of hours, and am now ready to throw the thing out of the window and spend my money on something else / better.
Anyone got any ideas or support (or have one or similar setup and working) that you could share with me?
Thanks in advance everyone!
2 REPLIES 2
Reddit
Message 2 of 3
Re: Wireless Access Point Help (Netgear WG103)
@monkeybutler wrote:
Hi All
when you say qiven, do you by any chance mean, given by BT?
Message 3 of 3
The wireless access point must be on the same subnet as the home hub, otherwise it will not work.
If you give the access point a static IP address of 192.168.1.16 (example), then it should connect to the home hub provided you run a cable between the two.
There are other options on this page.
Wireless connection problems
