Message 1 of 5
Wireless CNX just keeps dropping out
I used to have problems a while back but IMJOLLY fixed things for me, changed the main plate etc disconnected a few wires from the extensions
I have BT Bband, Home Hub 4 get a decent cnx for this area, just over 5
However every 5 minutes or so the wireless signal just drops< i have reset router, reset network adaptor, changed channels etc etc
What else could I do to try and resolve this please as I am now at a loss.
I don't have a phone connected just bband and have no other extensions in use
4 REPLIES 4
Message 2 of 5
Re: Wireless CNX just keeps dropping out
Have you turned off smart wireless and then selected your own channels?  Have you split the 2.4 and 5ghz networks by say adding a 5 to the 5ghz network. You can keep the same passwords. Some devices don't like the joined networks
Message 3 of 5
I have turned off smart wireless and selected my own channel, alas i have no idea how to split the networks
If I look under home network, it does show a map for 2.5ghx and 5 all of my devices are shown on the 2ghz only
When the wife turned he ipad on that showed under 5ghz
It also shows an unknown device connected, which is a bit odd as we have no other hardware, so i deleted it
Message 4 of 5
anyone any ideas?
Message 5 of 5
go to huib manager then advanced settings then wirelessl the 5ghz then change to do noit sync with 2.4ghz network  you can then giv 5ghz different ssis say add a 5 toi end and you can keep same password for both
you then need to conenct any devices that can to 5ghz to both the 2.4 and 5ghz networks so then can change between them depending on signal strength
