Message 11 of 36
Re: Wireless Connection
yes that is correct connect one powerline to your hub and the other to your MAC and the household mains circuit does the rest it is that simple
Message 12 of 36
And will give you the full connection speed.
Message 13 of 36
Thanks again.
I should have asked how one connects from 1st pwer line socket to HH3?
Message 14 of 36
Short Ethernet patch cable at each end.
Try    TP-Link TL-PA211KIT 200Mbps Mini Powerline Ethernet Adapter - Twin Pack
for powerline adapters.
Message 15 of 36
Thanks. I see the twin pack in Amazon.
Do I need wired up 2M Ethernet Cable and/or TP link TL-PA211 200mbps Mini powerline ethernet adaptor-single pack by TP-Link?
Amazon also sell Home plug? Quandry
Message 16 of 36
No you need
1 off      TP-Link TL-PA211KIT 200Mbps Mini Powerline Ethernet Adapter - Twin Pack
And
2 off     Wired--up 2M Ethernet RJ45 Network Cable
Provided 2 Metres is long enough each end, to reach from the home hubs mains socket, to the home hub Ethernet ports
And at the other end
From the mains socket (not a filtered one) that your iMac plugs into, to your IMacs Ethernet port.
We are not allowed to post direct links here. If you still can`t locate what you need, then send me a personal message.
Message 17 of 36
OK thanks. Off I go.
Message 18 of 36
Update
Just received the twin pack which also contained 2 ethernet cables. A question;-
I know it's not a BT thing but I have a Time Capsule external back up which need to connect by ethernet from HH3 direct to WAN port of Time Capsule hard disc then wirelessly to iMac.
I am presently unable to use this back up as HH3 to ethernet connection is too far away.(the reason I am using TP-Link)
I ask if you think I should be able to utilise TP Link to help in a similar way to my earlier problem?
Message 19 of 36
Is either end of the TP link near to the Time Capsule?
Message 20 of 36
Thanks for reply
Yes the end near to iMac is nearby but the link only has one ethernet port
