Message 21 of 36
Re: Wireless Connection
@robboz wrote:
Thanks for reply
Yes the end near to iMac is nearby but the link only has one ethernet port
That is very easy to solve, just add an Ethernet switch, like
TP-Link 5-Port 10/100 Unmanaged Mini Desktop Switch (TL-SF1005D) £6.99
That will leave you four spare Ethernet ports.
Message 22 of 36
Thanks again. I wd mention that my Time Capsule has 3 spare ethernet ports-do I connect the TP-Link plug to the switch with the ethernet supplied then from switch to one of the Time Capsule's ethernet ports leaving the WAN port empty?
Sorry to be pedantic.
Message 23 of 36
I am not familiar with the time capsule, but if  it has spare ports, then maybe they can be used instead of adding an extra switch.
Connect the TPlink to one of them, and your wired computers to the rest. Unless you need more than two Ethernet connections?
Message 24 of 36
Thanks-the TP switch is on its way.
I may get a result by running ethernet from TP power socket near iMac connected to house mains, to the TP switch and then to both iMac and Time Capsule by 2 ethernet cables.
I'll be back
Message 25 of 36
Networking can be fun, but quite challenging at times Smiley Wink
Message 26 of 36
Understatement of the year! Thanks for your help without which it wd be impossible.
Message 27 of 36
Its no problem. I have had many years of experience in this area (now retired).
Pop back here if you need more help Smiley Wink
Message 28 of 36
I now have a silly question. Do the Powerline Adapters somehow replace the normal home electrical power plug or do i need double plugs at each end, one for the router  and Powerline at one end also a double for Imac and Powerlinee the other end.
I guess two doubles is the answer?
Message 29 of 36
Most, apart from the ones that BT supply, do not have a pass through connection, so you will need a double socket.
Message 30 of 36
Thanks again
