Shaptor
Message 1 of 12
Wireless Hub Connection Unreliable When Watching Video
Recently upgraded to Hub 2.0 with hub phone.  Since the upgrade, usually when watching video, the hub drops the connection.  Sometimes I can reconnect from the pc by disconnecting and then reconnecting, but mostly I have to reset the hub. This never happened on Hub 1.0 (which was on Option 1) but has always happened on Hub 2.0 (on Option 3).
I am running Windows 7 on a new laptop with IEEE 802.11n. The signal strength is 'good'.
Anything I can check out?
Tags (4)
11 REPLIES 11
shawad
Message 2 of 12
Re: Wireless Hub Connection Unreliable When Watching Video
I've had the same problem for months - BT's response was it couldn't possibly be their equipment, it must be that ALL of my 4 wireless-n WiFi Alliance CERTIFIED devices must be faulty, or the channel (despite InSSIDer saying nothing else was using channel 4).  The last suggestion was to turn off wireless-n...
Eventually got them to replace the Type A hub with a Type B and surprise surprise I've not had the disconnect since.
Distinguished Guru
Message 3 of 12
I would suggest that you check to see if you get the same problem with a wired connection, It could be interference on the wireless, by using a different hub at default they could be on different wireless channels.
Download inSSIDer this will show you a graph of other wireless routers in your area and what channels they are using
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Shaptor
Message 4 of 12
Thanks for the tips. According to inSSIDer there are two other wireless access points using the same channels (9 to 13) on 802.11n; BTFON and BTOpenzone.  These are presumably neighbours' devices. The signal strength shows that from time to time all three wireless signals are running at -70dBm. My hub is usually running at -60dBm, but dips for a few seconds every minute or so.  This presumably will cause interference if I'm streaming a video and cause a loss of signal and a reset?
Question is therefore how can I boost the signal from the hub and/or change to a different channel setting?
Message 5 of 12
They are both coming from your hub and shouldn't cause you a problem.  You can opt out of btfon and there are posts on the forum which explain just use search
Shaptor
Message 6 of 12
Just noticed the MAC addresses of all three devices are the same!  Is the hub multi-personality?
Tags (3)
Shaptor
Message 7 of 12
Well if there are no interfering devices and the hub is providing a good signal between -60 and -70 dBm, is there another reason for the problem?
Tags (2)
Shaptor
Message 8 of 12
Thanks shawad. Just checked and this is a Type B.
Distinguished Guru
Message 9 of 12
BTFON and BTOpenzone are both being broadcast by your own hub. See http://www.btfon.com/
You can opt out of BT Fon if you want to.
Distinguished Guru
Message 10 of 12
If you want to change the wireles channel on a HH 2 click Here
You say that your HH is on channel 9-13, best to check the results in the table rather than the graph, I suspect the hub is on channel 11 as that is prob the centre point on the graph.
I suggest you change to a lot lower channel. maybe CH 1, although it can be a case of changing channels, trying it, if not change it again.
