imjolly
Message 11 of 18
Re: Wireless Password.
It is. Hub problem if it is letting devices connect with An old password. Only one password should be able to conenct and anything else is a hub problem
gg30340
Message 12 of 18
I guess we'll need to wait and see how the OP gets on with it.
Donsky
Message 13 of 18
OK, have reset the hub but it's still the same (Samsung devices on old password, everything else on new password), I've gone through the "forget connection" on the Samsung devices several times to no avail. I don't understand what's going on but as everything is now working OK I'm tempted to leave it as it is, now to load everything back onto the Samsung units that has been erased by the "master resets".
Regards.
gg30340
Message 14 of 18
Just to clarify. It is your Homehub SSid (name) that you are connecting to and not BTWifi. It should be something like BTHomehub5-xxxx.
Have you split the 2.4Ghz and 5Ghz frequencies on the Homehub?
If you have,did you check that the "New" password has changed on both the 2.4Ghz and the 5Ghz. It may be that your phone and tablet are connecting on the 5Ghz which may be still using the "old" password
Donsky
Message 15 of 18
Well done gg30340 you've hit the nail on the head, it's because the frequencies are split (don't know why because I've not done it), the Samsung units are using 5Ghz and everything else is using 2.4Ghz. Now the next obvious questions are: 1. how do I put both frequencies on the same password. 2. what's the benefit of having 2 frequencies.
Regards.
Donsky
Message 16 of 18
OK, have sorted question 1 out myself, didn't realise you can switch between 2.4 and 5Ghz in the advanced setting in hub manager, still not sure why the 2 frequencies though.
Regards.
imjolly
Message 17 of 18
5ghz gives faster transfer rate and less congested as fewer devices can use 5ghz but distance covered from router is lesss than 2.4ghz
gg30340
Message 18 of 18
Glad to hear it is sorted.
