wrighty434
Message 1 of 3
Wireless Speed
We have just had infinity installed and the speed on the main computer is very good indeed, 38 meg at the last check. My computer connected wirelessly is seeing speeds of around 14 meg using a 54mbps dongle. While that is good I was wondering if i got a 150mbps dongle would my speed increase significantly?
Cheers,
Stu
2 REPLIES 2
grinder4059
Message 2 of 3
Re: Wireless Speed
wrighty i had a similar problem while using my old laptop speeds down were around 22
8 up..
 however i treated myself to a new laptop with latest drivers etcetc and am getting speeds now around 37 down so having the latest equipment certainly does make a difference
hamish72
Recognised Expert
Message 3 of 3
Re: Wireless Speed
Installed wifi cards do seem to out perform usb dongles I doubt you will see much difference
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
