sdalgl72
Message 1 of 8
Wireless actually transfer rate seems a bit low
Hi all,
Something I was just wondering was what makes the BT HomeHub 3 decrease its actual transfer rate on Wireless as I am currently sat at on a Wireless connection that the Wireless adapter says it is connected at 39.0 mbs and then I look on the Hub and it says 11mbs and I am the only one connected to it.  How come these stats don't match? To me they should.
7 REPLIES 7
Webby
Message 2 of 8
Re: Wireless actually transfer rate seems a bit low
I've seen this before. I would take the computer reading as the more accurate one.
sdalgl72
Message 3 of 8
The main reason I ask this is because I was wondering if the Hub was getting stuck at that transfer rate and could be slowing everything up. Admittedly right now I haven't seen a slow down.
gouldyyyy
Message 4 of 8
Are you using the HomeHub with the version 4.7.5.1.83.8.57.1.3 (TypeA) (http://bt.custhelp.com/app/answers/detail/a_id/32228) ? Because if so, then that firmware has a lot of bugs in it, and may be your explanation.
Interestingly I compared mine to my Mac and Hub 3 (Type B) and this is what it came out at:
sdalgl72
Message 5 of 8
Speed has dropped a bit but can see what I mean
gouldyyyy
Message 6 of 8
Hmm, as Webby says, the computer looks more accurate, you could try changing the Wireless Interface Type to (40Mhz) thats what I have it set to, and see what it says, you may want to remove the top pic as you have your Wi-Fi key on there 😛
sdalgl72
Message 7 of 8
Yeah realised that after I posted it.  Not to worried about it to be honest was just trying to work out which was right, or is it an indication that is what the hub is running at.  If so how do I improve it?
sdalgl72
Message 8 of 8
It seems that it is only my N Standard wirless adapter that has this problem.  As it is the furthest away from the hub I'm guessing that is why I am facing this issue however I am not sure why.  Think I am just going to leave it along as there isn't anything wrong with the hub getting the wrong speeds.
