Message 1 of 3
Wireless connection to BTHub4 no longer automatic
Before my new Hub4 was connected as part of my Infinity package, my PC used to connect automatically to the hub when it booted up and ran Windows. Since installation of the new Hub4 and start of the Infinity service, I have to 'manually' connect every time I boot up. I 'hover' over the wireless icon and it tells me connections are available; I click the icon and I get a list of possible connections, one of which is my new Hub4. I have to click on that, and then click the "Connect" button. As far as I can see, various settings indicate it should be connecting automatically. Any tips please?
2 REPLIES 2
Message 2 of 3
Re: Wireless connection to BTHub4 no longer automatic
Delete any existing wireless connections on the PC, then rescan for wireless networks, and enter the passkey again. It should save the new credentials.
Message 3 of 3
Thank you.
