andy_finlayson
Message 1 of 7
Wireless connection to mobiles
Hi there,
I'm having some trouble with the new BT infinity wireless connection for the mobiles in the house.
Using the HH3.
Wireless connection between the 2 laptops in the house is fine and the wired connection fine.
However keeping a connection on the mobiles is struggling.
On my iphone 3gs i can connect to my wireless network and shortly after will be disconnected and join a neighbours bt openzone network which gets me to a splash page. Basically useless.
The same happens on my housemates HTC desire.
If i stare at the wireless light on the HH it will occasionally blink, this times in with the phones disconnect.
The log seems to be useless because all it shows is the connections not the disconnections
The HH is located in the exact same spot the router was when i was on virgin previously and had no problems whatsoever, (with the local network, the overall connection was poop). This old router seems to have bricked itself somehow and is not available to test with.
Is this a common fault?
Can i replace the HH with another router? for instance a D-Link 825?
I don't hold much stock generally with generic ISP supplied kit so replacing the router isn't really a problem as it's kinda expected.
6 REPLIES 6
Message 2 of 7
Re: Wireless connection to mobiles
have you tried changing the wireless from b/g/n which is the default to just b/g?
andy_finlayson
Message 3 of 7
yes i've already reluctantly set it to b/g
Message 4 of 7
the HH3 is supposed to change channel automatically to avoid conflict with other networks.  maybe you can try manually selecting a free channel or at least away from neighbours channel.
try downloading inssider2 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. Then enter your router and change your wireless channel to a free or less congested channel.
andy_finlayson
Message 5 of 7
i can see the channels in use locally from a D-Link usb dongle app.
I've had it on channels 1 and 2 for the last few days after the problem persisted on channels 6, 8, 11
Edit: could someone please clarify as to whether the HH3 can be replaced by an alternate router off the shelf or is the home hub somehow required to be used?
andy_finlayson
Message 6 of 7
bump for simple answer
Could someone please clarify as to whether the HH3 can be replaced by an alternate router off the shelf or is the home hub somehow required to be used?
Message 7 of 7
you can replace the HH3 with a cable router off the shelf - many have I think
