dj1891
Message 1 of 9
Wireless drop outs and general rubbish speeds?
I have been having issues with my broadband since last October.  I have regular broadband with a max of 7.5mb.  I had been using a BT Hub 4, the problem was the wireless would just drop out several times per day, the only solution being to turn the hub on and off and all back to normal for what could be 5 mins, it could be 5 hours but rarely would you get a full day without the wireless dropping out several times.
Finally BT admitted the Hub is faulty and are in the process of sending me out a new hub, I got fed up waiting and went out and bought a brand new TP Link router, as I red Hubs in general are rather **bleep**, this Router had good reviews so I said sod it and bought it thinking that would be the end of the problems.
Now I think the below says it all, less than 1mb speed even though I have a connection rate of 8mb.  Any ideas what wrong now?  It seems I two options, I can use a Hub which will give me 5-6mb download speed pretty constantly but drop out minimum 5 times per day, or I can use this router which would give speeds of more than 1mb but wont drop out.  Any advice?
 Download speedachieved during the test was - 0.68 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
8 REPLIES 8
john46
Message 2 of 9
Re: Wireless drop outs and general rubbish speeds?
Was the speedtest done with a wired connection
dj1891
Message 3 of 9
That wasn't no.  I just did another connected wired and it is slightly higher,
Download speedachieved during the test was - 1.1 Mbps
john46
Message 4 of 9
can you post the stats from your router
dj1891
Message 5 of 9
I'm not sure how I do it.
Line Status:Connected
DSL Modulation Type:ADSL_G.dmt
Annex Type:Annex A/L
  Upstream DownstreamCurrent Rate (Kbps)Max Rate (Kbps)SNR Margin (dB)Line Attenuation (dB)Errors (Pkts)
4488128
10968800
214.7
86.5
00
dj1891
Message 6 of 9
I should add I'm using a TP Link W9970
dj1891
Message 7 of 9
Right guys, Its now 6.30 am, I wired up my BT hub again as a speedtest now on the TP link still showed poor speeds.  At this time of the morning I should get 7mb download, on the BT Hub I am getting 0.85mb.
So thats 2 routers with 2 different microfilters giving carp results, the IP Profile of the line is still 8.15mb so that hasn't dropped, its not congestion at the exchange, so what is the problem? 17070 gives no noise on the line.
john46
Message 8 of 9
I have asked a forum moderator to help you they will post their contact link here
JohnC2
Moderator
Moderator
Message 9 of 9
Hi @dj1891 Sorry you are having trouble with your broadband connection.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
