louey
Message 21 of 24
Re: Wireless drops out when phone is used
Ok - I will contact BT. Will they charge me for coming out? (I'm guessing the answer to this is yes...)
Distinguished Expert
Message 22 of 24
Only if you caused the wiring problems
To say thanks for a helpful answer, please click the white star
Message 23 of 24
Not if its an external fault. I suspect a corroded joint on the network somewhere.
Here is a guide as to whether you are likely to be charged.
Engineer visits – information and charges
If you get nowhere with this fault, then one of the moderators may be able to help.
louey
Message 24 of 24
Thanks for the link. We haven't touched the phone lines so hopefully they won't charge us.
