Message 30 of 276
Re: PC will not connect to BTHub3 by wireless.
Its a network device, and that is why it appears on your network map. If it did not, you would not be able to connect to the home hub manager.
chris6273
Recognised Expert
Message 32 of 276
Re: Wireless internet keeps dropping
Hi Afterthought, Welcome to the Forums 🙂
Have you tried changing your Wireless channel?
To do so, go to 192.168.1.254 -> Settings -> Advanced Settings -> Wireless -> Change the channel to a different one and hit Apply.
I hope this helps
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
Message 33 of 276
Also try changing to wireless b/g rather then b/g/n.
badgeb
Message 34 of 276
HH3 with WPA2 will not connect with wireless. Frequent drop outs to wired LAN.
Hi
I have a BT home hub 3 model B, when I set the encryption to WPA2 it will not connect wirelessly to IPAD2 , windows 7 laptop or to my Iphone4.
It will connect to these when set to WEP. Obviously WEP is insecure and I need to go to WPA2.
I am pretty convinced the client devices are not at fault. I have tried fixing the wireless channel to 11 , I have tried resetting the SSID and the key.
I have reset the system.
The software rev number is V100R001C01B028SP01
The default wpa2 key when I to complete reset appears to a a hex string.
The above devices will connect wirelessly to my upstairs netgear wireless access point via WPA2.
Also I get  Frequent drop outs to wired LAN - this impacts internet radio on Sonos and Pure systems
The HH3 is only recently installed and has old software - how do it get it updated please.
Any suggestions or help welcome.
BB
Message 35 of 276
Re: HH3 with WPA2 will not connect with wireless. Frequent drop outs to wired LAN.
Just set it to WPA only and not WPA/WPA2. WPA is quite secure enough.
badgeb
Message 36 of 276
Thank you for fast suggestion re WPA.
I tried it.
It did not work - both win7 and IOS devices say " unable to connect".
Any idea about firmware upgrade for hh?
Bb
Message 37 of 276
You will have to delete any existing wireless setting that may have been remembered, then re-create them again, as the encryption method has changed, and the devices do not know it, and tries to connect using old credentials.
Message 38 of 276
firmware is upgraded automatically by bt servers as and when available
Message 39 of 276
recheck your wireless security code is correct on the devices
badgeb
Message 40 of 276
OK guys
I forced everything to use new credentials by creating a new SSID and key in HH3, iphone and PC
did a restart.
It still does not work with WPA. not on pc, not on iphone.
I tried calling BT Broadband help, ended up talking to a lady in India - unfortunately rather cluelesss .
Did not know what encryption was!
BB
