curlew
Message 71 of 276
Re: Hub connects to laptop but no internet
Just wanted to add a final post to say that the updated driver + channel 9 worked (see previous post), and I now have web connectivity with WPA and WPA2 from the laptop.  Yay!
Thanks again to all.
Message 72 of 276
hi glad it is now solved for you 🙂
Message 73 of 276
Infinity wireless not working properly and another problem...
So basically, I have my iPad and phone connected up to my hub... This has been fine since Infinity was installed but now the wireless keeps disconnecting and re-connecting. It happens every minute or so which can be really annoying.
Also, my downloads keep stopping. No matter where I download from if it's a song from iTunes or some of my files from Mediafire, none of the downloads will complete. They get to a certain stage then the speeds just starts to drop and keep dropping until they hit 0kbps.
Message 74 of 276
Re: Infinity wireless not working properly and another problem...
Message 75 of 276
Yeah... I'm not the best with technical stuff. 😞
Message 76 of 276
Well the intructions that BT give on those links, are very easy to follow, but not on your mobile Smiley Wink
Message 77 of 276
Okay. I'll check it out when on my computer. Thanks.
wonkeroo
Message 78 of 276
Slow wireless connection - BT Home Hub 3
Hi guys,
My home network is running incredibly slowly and I was hoping that someone might have an idea for how to speed it up.
I have a NAS system connected to my homehub 3 and the maximum transfer speed that I get is 2 MB/s. I realised that this was a little slow, so I have tested various file sizes on 3 different computer, varying the distance from my router from sitting right next to it to the other side of the house and the issue has not changed. I have also done a speed check using 'LAN Speed Test' between 2 of the PCs and get a similar data transfer speed - no higher than 2.5 MB/s and down to 500 KB/s.
Does anyone have any ideas what could be causing such issues? I've tried switching channels, but that doesn't seem to have affected things in the slightest 😞
Message 79 of 276
Re: Slow wireless connection - BT Home Hub 3
wonkeroo
Message 80 of 276
Thanks for the rapid response. So basically I've had a look through those pages and it looks like it could quite possibly just be a Home Hub 3 problem 😕 That kind of sucks balls.
Hey-ho!
