Message 81 of 276
Re: Slow wireless connection - BT Home Hub 3
Well, if you read through the forum you will find that wireless problems are very common. WiFi works on an unlicenced frequency band which is shared by many different devices, so is subject to all sorts of interference.
It fine for web browsing or e-mail, but not usually for streaming media, unless you have a good signal, and every device is wireless "n" capable.
alien
Newbie
Message 82 of 276
Wireless link ok but no internet access
I have a BT Home Hub 3 physically connected to a PC which has full internet access. When I connect to the hub  via wireless it is saying that there is no Internet access available.
What am I not doing?
Message 83 of 276
Re: Wireless link ok but no internet access
have you disconnected the cable before trying wireless?
can you see your hub ssid in wireless networks available?  if so try and connect then enter the wireless password which is on pullout in hub
Message 84 of 276
alien
Newbie
Message 85 of 276
I am using two different PC's. One is a desktop which is physically wired to Hub and that works fine. The other is a laptop which connects via wirless perfect but the link is saying no internet access available
glynstacey
Message 86 of 276
Wireless
After my previous query regarding wireless card not picking up HH2, a question.
I had Infinity installed on monday and very pleased I am too. But, the same wireless card that wouldn't pick up HH2 wouldn't pick up HH3. It would pick up a Netgear, Talk-Talk, Virgin and Btfon but, not the hub that was about 15' away. My tecky took it back and it connected to about 6 hubs but, again no Bt hubs, but only a BTfon.
My question is this. I assume that the frequency of the hubs are all governed by set specs, so how come the BT hubs seem to have a frequency outside of the card specs in my clunker? My tecky says it's 'bizarre!' and a friend who knows an awful lot about TV and wireless is completely baffled.
Any thoughts?
Glyn.
Message 87 of 276
Re: Wireless
have you tried checking the manufacturers website for an updated driver for you network card.
if you card is not 'n' rated have you tried changing the hub from default b/g/n to just b/g?
Message 88 of 276
Re: Wireless
See Wireless Help
The most likely cause is that your wireless card cannot cope with WPA/WPA2.
glynstacey
Message 89 of 276
Re: Wireless
Thank you for that you two! G.
Message 90 of 276
Re: Wireless
I assume from your nice comment that you managed to get it to work
