Message 21 of 59
Re: Wireless keeps dropping out even with a brand new home hub !!
I know what you said about wanting to use 'n' but have you tried to change to b/g to see if that does cure the problem.  That way you would know that it's not the wireless that is the problem but the b/g/n
Distinguished Guru
Message 22 of 59
@imjolly wrote:
I don't know if there is a new router for infinity.
According to this post by Titanic - http://community.bt.com/t5/BB-in-Home/BT-Home-Hub-3/m-p/99661#M52508 - the hub 3 works on adsl AND InfinitySmiley Surprised
-+-No longer a forum member-+-
Message 23 of 59
just a wait and see thenSmiley Wink
Distinguished Guru
Message 24 of 59
@ Imjolly, aye we should know soon...
@MandiMoon, there is another infinity user currently having problems (may be worth a read) - http://community.bt.com/t5/BB-in-Home/New-Infinity-install-great-so-far-except-for-dodgy-HH-wifi/m-p...
MandiMoon
Message 25 of 59
I dont even have any G adapters now ! Grrrrr
But if the b/g/n is at fault its still teh wireless ! It should work with N ! You need N for the speed on infinity else.... whats the point ?
Message 26 of 59
the 'n' adapters will be backward compatible so will work with 'g'  if that works it may then be the 'draft N' that is the problem
MandiMoon
Message 27 of 59
Thanks.... I added to that one yesterday ! Another one the same and totally un-solved 😞
MandiMoon
Message 28 of 59
Oh I see... .so just change the setting on wireless to B/g and leave the N ? Worth a try next time it drops out..........watch this space
Message 29 of 59
yes just change router to b/g and leave the adapters - they will sort themselves
planetf1
Expert
Message 30 of 59
Yep the other thread was me! -- There are a lot of apparent wifi issues. Obviously a lot of customers, and can be a variety of factors, but my gut feel is that the current sw/hw level is fundamentally flawed..
