Marco0208
Newbie
Message 1 of 6
Wireless light on & off
Hello !
My connection keeps dropping off today and i realised that my wireless light is dropping most of the time ( the wireless light is blue but suddenly disappeared and came back on immediately again)
I use BT home hub 3 as well
Many Thanks
5 REPLIES 5
Message 2 of 6
Re: Wireless light on & off
hi sounds like a possible faulty hub suggest you contact the help line and ask them to send you a replacement hub
Distinguished Guru
Message 3 of 6
John's probably right, but does the hubs wireless light 'flicker' when smart wifi fires in?
To check I'd manually set the wireless channel and then see if it still goes out.
-+-No longer a forum member-+-
Marco0208
Newbie
Message 4 of 6
Just switch to channel 11 and the wireless light stays on !!!
Distinguished Guru
Message 5 of 6
Leave it there and see how it goes
(report back in a few days with any news, unless it drops out again)
Message 6 of 6
another smart wi fi problem not that smart
