Kaira_95
Message 1 of 16
Wireless ok but no ethernet - going insane!!
Hi,
See title - I just don't know what to do anymore and the more I search for info online the more confused I get.
gear: HP laptop with Vista and BT hub 3.0 type A
symptoms:
- Ethernet connection is local only.
- The network is "non identified" and "public". Tried to change it to "private", it doesn't work.
- In a command window IPCONFIG is "not recognized as an internal or external command, operable program or batch file".
- "PATH" does contain "system32".
- Cables are ok. swapping ports doesn't change anything.
If anyone knows how to fix this, please show up... thanks...
15 REPLIES 15
Message 2 of 16
Re: Wireless ok but no ethernet - going insane!!
has this just happened does it affect only on device or more have you tried a factory reset of the hub
Kaira_95
Message 3 of 16
Yes I pressed the reset button on the hub but it didn't help. My network card driver is up to date too, or so it says
Message 4 of 16
the factory reset normally needs a pin or similar to activate the factory reset feature
Message 5 of 16
To do a factory reset of the homehub ypu need to press a pin into the recess button on the rear for about 20 seconds.
West
Message 6 of 16
I had a similar problem.
The recent updates form Microsoft now changes your drivers.
My ethernet card could not work with the new driver. Nothing I have done has sorted this.
The answer was a to buy a USB Ethernet adapter. I bought one from StarTech.  USB3.0 TO Gigabit Adapter
This has returned me to full speed.
Message 7 of 16
If an updated driver caused you problems you should be able to roll back the driver to the previous one. If that does not work try uninstalling the network card, restart your computer and let Windows re install it.
Kaira_95
Message 8 of 16
I did hold the reset button for 20 seconds, in fact doing this I was on the phone with someone from BT...
As for the driver issue... I just completely reinstalled Windows back to factory settings, but even before that I could never use the ethernet connection. I also just installed a dual boot Ubuntu, and it can't detect any sort of connection at all. It might be a dumb question but do you need different drivers for the same devices whether you are using Linux or Windows OS?
That filter isn't cheap but it could be the solution indeed 🙂
Message 9 of 16
Re: Wireless ok but no Ethernet - going insane!!
You will need different drivers for you Linux operating system.
Can you now use the Internet since you re installed Windows. Have you checked the Device Manger if the network card is installed and working.
In Windows go to Start > Control Panel > Device Manager > Network Adaptors. You should see your Ethernet card there.
EDIT: Do you have another computer/laptop that you can connect to the homehub to see if it works?
Message 10 of 16
Did you carry out the Windows re install before or after this problem started?
