I have a HH 2 Type B and all laptops that ever use the same achieve a good wireless n connection .... router access is set to b/g/n.
I am contemplating getting a wireless printer (all-in-one) but few seem to come with both Win 7 & wireless n. If I install one that has wireless b/g will it all work ok with the laptops keeping their stable n connection ?
I have heard this may well not be the case and I would need to set them all to g ...... any comments on that information ?
Richard
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings Star on the left-hand side of the post.
