Message 1 of 4
Wireless range issues. HH5 secondary access point.
I have been having trouble with wireless range in my home. Previously I had a HH5 and created a secondary access point with a HH4 based on keith_beddoe's guide after having no success with a TP-Link wifi extender.
http://forumhelp.dyndns.info/wireless/hh3link.html
This proved successful to a certain extent, but after a while the speed on the second access point would drop dramatically. This would only be restored by resetting the secondary HH4.
I now have two HH5's connected using the same method and so far it seems to be working relatively well, however the second HH5 has occasionally reset itself (twice in 1 hour). Is there any way to prevent this from occuring? Or perhaps, as stated on a previous thread the HH5 is less compatible operating as a slave hub. Maybe the HH4 has more merit in terms of acting as the access point? For the setup I have set both hubs to the same SSID's and wireless keys.
I had an engineer at my property last week for 4 hours and the wireless range had him stumped Smiley Frustrated
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Wireless range issues. HH5 secondary access point.
Hi rstor212,
Welcome and thanks for posting. I appreciate it's quite an old thread but does this help?
Cheers
David
Message 3 of 4
id forget 2nd hubs and go for a wifi extender that uses the houses wiring rather than trying to repeat the signal. the usual wifi extenders just repeat the signal, so in effect you get a better more stable connection with a little boost. you can get wifi extenders which work similar to home plugs, ethernet directly to the hub, then the 2nd plug transmits the wifi signal at full strength. i think bt sell one but im not sure, also the 3nd plug that emits wifi usually has the option of ethernet too.
Message 4 of 4
Hi David,
Thanks for the response. I thought I had my email alerts setup for this but apparently not :/.
Unfortunately I had already visited that forum prior to posting my original message with no joy.
But thanks again for the reply.
