toobuddy
Message 1 of 6
Wirelss security
A very simple question - is there a quick way to ensure that my wireless is secure from unauthorised users connecting?
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Wirelss security
Its already secure, as its protected using a wireless encryption key. Unless you give somone else the key, they cannot connect to your wireless network.
toobuddy
Message 3 of 6
Thanks!  That's great.
zardoz
Message 4 of 6
hi i was wondering if i can check with you too keith regarding this, i have just had infinity installed and when i check in troubleshooting under wireless and firewall i see a lot of remote attempts on my router? here are a few of the 'attempts' theres lots more! hopefully you can advise me if i need to check or change anything? many thanks, sorry to jump into this thread :s
22:12:59, 18 Mar.    IN: BLOCK [15] Default policy (TCP 173.194.34.126:443-?>86.176.34.181:49345 on ppp3)
22:12:53, 18 Mar.    BLOCKED 2 more packets (because of Default policy)
22:06:48, 18 Mar.    IN: BLOCK [12] Spoofing protection (IGMP 192.168.1.254-?>224.0.0.22 on ptm0.101)
22:24:20, 18 Mar.    IN: BLOCK [9] Packet invalid in connection (TCP 173.239.79.210:443-?>86.176.34.181:49683 on ppp3)
22:24:16, 18 Mar.    BLOCKED 1 more packets (because of Packet invalid in connection)
22:24:16, 18 Mar.    IN: BLOCK [9] Packet invalid in connection (TCP 173.239.79.210:443-?>86.176.34.181:49683 on ppp3)
22:24:14, 18 Mar.    BLOCKED 1 more packets (because of Packet invalid in connection)
00:36:16, 19 Mar.    IN: BLOCK [15] Default policy (TCP 198.136.44.139:35202-?>86.176.34.181:44588 on ppp3)
00:35:23, 19 Mar.    IN: BLOCK [16] Remote administration (TCP 64.237.37.175:40414-?>86.176.34.181:22 on ppp3)
00:33:38, 19 Mar.    IN: BLOCK [16] Remote administration (ICMP type 8 code 0 130.161.3.170-?>86.176.34.181 on ppp3)
Keith_Beddoe
Message 5 of 6
Nothing to worry about, its just the firewall and IDS (Intrusion Detection System) doing its job by blocking connections from the Internet which are either invalid, or attempts to look for open ports.
zardoz
Message 6 of 6
thanks Keith, wasnt sure if they were someone tryin to bruteforce already! only had it installed a couple of days 🙂 , cheers for the quik response !
