alones
Message 1 of 20
Wirless now rubbish
We have always had a good connection speed as we are close to the exchange. But over the last two weeks the wireless connection speeds are almost constantly under 1 meg 😞 sometimes creeping up to 7meg (for a short time only).
Just looking at the my stats. There appear to be alot of errors - any suggestions ???
ADSL line status
Connection Information
Line stateConnected
Connection time6 days, 03:19:17
Downstream23,792 Kbps
Upstream1,144 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeFast
Noise margin (Down/Up)2.5 dB / 6.6 dB
Line attenuation (Down/Up)12.0 dB / 3.2 dB
Output power (Down/Up)36.2 dBm / 1.7 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)58461 / 0
HEC Errors (Down/Up)33040 / 0
Error Seconds (Local/Remote)45385 / 0
19 REPLIES 19
Message 2 of 20
Re: Wirless now rubbish
Hi Welcome to the forum
This link may help you http://www.btinternet.com/~cbeddoe/wireless/hub3_wireless.html
It may also help if you download   insidder and then select a free wireless channel
it sounds like wireless interference could be your problem
Message 3 of 20
Is the speed the same when connected using an Ethernet cable, and is it much slower after dark?
Message 4 of 20
Then your problem is more likely due to a low downstream noise margin.
See Noise margins
It looks like its only 2.5db  at the moment. I suspect it drops lower later, and the CRC events start clocking up.
Message 5 of 20
keith the errors don't seem very high bearing in mind that connection time is 6+ days
can you run btspeedtser beta version and post when you see slow download.  there is no restriction on the number of times you can this beta version
Message 6 of 20
Its stil 9700 CRC errors a day, and if most of them are in the evening, that is when the margin is going to drop.
The best way is to wait until it slows down, make a note of the noise margin, and check the CRC events every 30 second or so, to see if they are clocking up.
There are also a large number of errored second, which indicate noise or interference.
The usual "test" socket test would be best, and see if the noise margin goes up a bit.
Message 7 of 20
be interesting to see if they increase substantially at night but 9700 crc over 24hrs is only 6/7 a minute and on fast that does not seem alot of errors - unless they all happen in a couple of hours at night
alones
Message 8 of 20
Keith
The ethernet connection is fine - about 18-20 meg. It is only wirelss on a selection of devices. Seems no pattern to the dips, ie does not relate to time of day - never even got up to 1 meg all of yesterday afternoon. Currently running at about 13 (which is fine).
alones
Message 9 of 20
Will post a speed test when it next slows down.
Thanks to both for your help
Message 10 of 20
wireless is never reliable for the maximum speed there are to many sources of interference to slow it down also unless all your devices are wireless n enabled the slowest device will set the speed for all devices set for example a wireless g laptop will cause a wireles n laptop to connect at g speeds
