andy_p
Message 1 of 25
Woolhampton Exchange Performance Issues - moderator please help
Hi All,
As I suspected from original post (knotty issue) we have a network congestion  issue at Woolhamton . @egw21 has seen the same issue in the same time frame.
Quick Summary:
 I'm synching at > 11Mb/s but download speeds collapsed in the evening at or around 20/11/17
Logged fault, but fault desk fell back on 1mb/s despite measure download in the evening previously being > 4.5Mb/s streaming. The line has been so good I had given testing and started investing in streaming hardware (appletv) and subscriptions ... fool on me.
However... I got a call from the Indian call centre asking if my fault had been fixed .. NO
Engineer visited 29/11/17 .. Comfirmed  clear line (digital & analogue), but after a call in discovered that I still had capping on my line ( the old capped broadband .. go figure). And for my trouble he doubled my SNR to 6db down , 12 db Up, which took my upload to 888 , and took off fastpath (thanks a lot!). No errors recorded by my router for the next 24Hrs , but download speeds after 3:30pm collapse and by 11:00pm they were below 1Mb/s .. thakfully I got speedtest wholesale to actually accept that number for future reference.
Today (30/11) call back from Indian call centre asking whether things had improved. Answer NO, they will call back tomorrow.
An hour later, link goes down for ~ 60 secs before resyching at 9dB download SNR. That was clearly an intervention , since there were zero errors (ES, SES) prior.
Seems like Openreach think it's a line issue ( not so) rather than a backhaul issue. Perhaps becuase the call back fault said dropped connection (not my fault call remember).
Reminds me of the saying when you only have a hammer every problem looks like a nail.
24 REPLIES 24
egw21
Message 2 of 25
Re: Woolhampton Exchange Performance Issues - moderator please help
Thank you for copying me in - moderators please see my earlier email trail.  I am a way from the exchange so realistic in expectations but the drop from nearly 3 mb/s to below 0.5 at times and max 1 in recent weeks has been a disaster.
imjolly
Message 3 of 25
you need to post btspeedtester results both peak and off peak to show your problem - and it records on wholesale database
egw21
Message 4 of 25
OK thanks.  Will do tomorrow
XRaySpeX
Recognised Expert
Message 5 of 25
Please post your full Router Stats. For a Home Hub see on here: Broadband Top Tips . Full router stats are key to any speed & connection issues.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
andy_p
Message 6 of 25
Unfortunately I can't post by screen grabs too large
at 22:31 Wed 29
Download 0.87 , Acceptable Range 4 - 21Mbs , IP Profile 10.65Mbs
Upload 0.68 , IP Profile 0.83
(so logged succesfully)
Which refered to TAP3 testing which I didn't want to do since it resets router stats
Line Synched 11+MBs 888kbs
Off Peak data is 10 + Mbs
BUT to day has been ~ 2 -3 Mbs at quiet periods so clearly something is happening at th exchange
Router stats
Uptime 1hr 23  see early in the thread about Openreach initiated blip to 9db SNR for no reason
The MSO/DSM was happy with 3db , & fastpath before manual intervention on their side.
Mode   ADSL_2plus
Traffic Type     ATM
Status  Up
Link Power State         L0
Downstream   Upstream
Line Coding (Trellis)    On       On
SNR Margin (dB)        8.4       11.5
Attenuation (dB)         37.0     20.5
Output Power (dBm)  0.0       12.6
Attainable Rate (Kbps)           11040  888
Rate (Kbps)     10429  888
MSGc (# of bytes in overhead channel message)     59        10
B (# of bytes in Mux Data Frame)      162      13
M (# of Mux Data Frames in FEC Data Frame)         1          8
T (Mux Data Frames over sync bytes)            2          9
R (# of check bytes in FEC Data Frame)         12        16
S (ratio of FEC over PMD Data Frame length)           0.4985 4.0000
L (# of bits in PMD Data Frame)        2808    256
D (interleaver depth)  64        8
Delay (msec)   8          8
INP (DMT symbol)      1.00     2.00
Super Frames 278395            246970
Super Frame Errors    16        0
RS Words        36191389        216108
RS Correctable Errors 867      55
RS Uncorrectable Errors         581      0
HEC Errors       418      0
OCD Errors      0          0
LCD Errors       0          0
Total Cells       110963709      9443838
Data Cells        2768883          360654
Bit Errors         0          0
Total ES           10        0
Total SES         0          0
Total UAS        0          0
andy_p
Message 7 of 25
Just for completeness @XRaySpeX this is a post from different thread showing the stats before the engineer gote higher SNR invoked
Model Name                           BiPAC 7800DXL
Host Name                              home.gateway
System Up-Time                     3D 20H 1M 49S
Date/Time                              Sun Nov 26 13:26:55 2017  Sync
Software Version                    2.32e
LAN IPv4 Address                    192.168.1.254
LAN IPv6 Address                    fe80::204:edff:fefa:2910/64
MAC Address                          00:04:ed:fa:29:10
DSL PHY and Driver Version    A2pD039f.d24m
Wireless Driver Version          6.30.102.7.cpe4.12L08.4
WAN
Line Rate - Upstream (Kbps)              1103
Line Rate - Downstream (Kbps)         12211
Default Gateway / IPv4 Address        pppoa0 (DSL) / 86.179.157.128
Connection Time                                 2 Day(s) 04:43:38
Primary DNS Server                62.6.40.178
Secondary DNS Server            213.120.234.74
Default IPv6 Gateway / IPv6 Address
Mode   ADSL_2plus
Traffic Type     ATM
Status  Up
Link Power State         L0
Downstream   Upstream
SNR Margin (dB)                                                        4.7                   5.4
Attenuation (dB)                                                         37.0                 20.6
Output Power (dBm)                                                  0.0                   12.4
Attainable Rate (Kbps)                                               13100              1104
Rate (Kbps)        12211              1103
MSGc (# of bytes in overhead channel message)     51                    12
B (# of bytes in Mux Data Frame)                              217                  33
M (# of Mux Data Frames in FEC Data Frame)         1                      1
T (Mux Data Frames over sync bytes)                                    2                      4
R (# of check bytes in FEC Data Frame)                     0                      0
S (ratio of FEC over PMD Data Frame length)                       0.5699             0.9784
L (# of bits in PMD Data Frame)                                3060                278
D (interleaver depth)                                                  1                      1
Delay (msec)                                                               0                      0
INP (DMT symbol)                                                      0.00                 0.00
Super Frames                                                             0                      0
Super Frame Errors                                                    282621            360
RS Words        0                      176534
RS Correctable Errors                                                 0                      0
RS Uncorrectable Errors                                             0                      0
HEC Errors        105523            780
OCD Errors        1332                0
LCD Errors        1332                0
Total Cells        942983383      860634176
Data Cells        84062374        7111044
Bit Errors        0                      26018
Total ES        57394              236
Total SES        193                  0
Total UAS        0                      0
andy_p
Message 8 of 25
Update
Had another call from the Delhi call centre , and they have escalated and scheduled what I guess is a broadband engineer (as opposed to the linesman that came yesterday)
So while I may be frustrated, at least the support protocol seems to have taken over
Andy
imjolly
Message 9 of 25
if it is congestion then nothing engineer can do to fix it
john46
Message 10 of 25
If it is congestion it is outside both BT Retail and Openreach's remit it is a BT Wholesale problem which they will be aware of and working on a fix although no timescale will be known
