-AndyH-
Expert
Message 21 of 36
Re: World of Warcraft latency?
To me, that looks perfectly fine and it looks like nothing to do with g.inp
Is the problem happening all the time or certain times?
jarsc
Message 22 of 36
Sorry got called away (domestic chores)
 It's really hard to articulate/ explain, The game isn't right, like it's mili-seconds behind. Then I enter a raid it gets worse, yet my latencey Worls and home is showing at 25ms, It feels like 300ms+.  And yes it always there, but gets worse in sertain situations. I'm getting 100+ FPS on high graphics, so it doesn't seem to be a system problem. The only thing that baffles me is the Addon "Quartz* showing latencey of 300ms, which is the only thing that feels correct!
jarsc
Message 23 of 36
Would you like me to try the path ping again?
-AndyH-
Expert
Message 24 of 36
To be honest, I'm not sure the path ping will show anything.
Can you pinpoint when it first happened? Has anything changed your end (new software/updates) that might coincide?
jarsc
Message 25 of 36
I have found a program assiciated with Blizzard, off their tech section called "Battle.net LOOKING GLASS".
It has run a network diagnostic test..... the results are as follows.
PING  (my ip) 56(84) bytes of data.
--- my ip ping statistics ---
4 packets transmitted, 0 received, 100% packet loss, time 5006ms
traceroute to my ip (my ip), 15 hops max, 60 byte packets
 1  Blizzard (Blizzard)  0.539 ms !X * *
 1  Blizzard (Blizzard)  0.547 ms  0.622 ms  0.698 ms
 2  * * *
 3  ams-ix.bt.com (80.249.208.108)  0.827 ms  0.848 ms  0.850 ms
 4  t2c3-xe-1-0-1-0.uk-lof.eu.bt.net (166.49.208.219)  7.414 ms  7.430 ms  7.435 ms
 5  213.137.183.39 (213.137.183.39)  7.510 ms  7.535 ms  7.540 ms
 6  core4-te0-7-0-0.faraday.ukcore.bt.net (62.6.201.168)  7.970 ms  7.969 ms  8.068 ms
 7  195.99.127.53 (195.99.127.53)  8.085 ms  8.131 ms  8.163 ms
 8  195.99.127.169 (195.99.127.169)  8.054 ms  8.037 ms  8.081 ms
 9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
-AndyH-
Expert
Message 26 of 36
It's trying to ping you, but your router will be blocking pings on the WAN.
I'm not sure what to suggest to be honest. There's nothing obvious that sticks out.
jarsc
Message 27 of 36
Thank you for you time 🙂
ray_dorset
Distinguished Guru
Message 28 of 36
To make pings work to you, you need to attach a device to the Homehub and put it in the DMZ. Something that responds to pings, like a spare router if you have one.
If not, I'll try again 🙂
ray_dorset
Distinguished Guru
Message 29 of 36
Or even your PC 🙂
jarsc
Message 30 of 36
There is another option on the looking glass called MTR I ran the suggested MTR and TRACEROUTE.
Results...
1 Blizzard (Blizzard) 0.530 ms 0.607 ms 0.720 ms
2 * * *
3 Blizzard (Blizzard) 10.828 ms 11.031 ms *
4 * * Blizzard (Blizzard) 11.014 ms
5 * t2c3-xe-11-1-0-0.uk-lof.eu.bt.net (166.49.208.82) 12.834 ms t2c3-xe-0-0-0-0.uk-lof.eu.bt.net (166.49.208.213) 13.426 ms
6 t2c3-xe-1-0-0-0.uk-lof.eu.bt.net (166.49.208.217) 12.860 ms 213.137.183.37 (213.137.183.37) 13.079 ms 213.137.183.39 (213.137.183.39) 12.989 ms
7 213.137.183.35 (213.137.183.35) 13.064 ms 13.430 ms 13.334 ms
8 core3-pos0-7-0-13.ealing.ukcore.bt.net (62.6.201.170) 13.522 ms core2-hu0-0-0-0.southbank.ukcore.bt.net (195.99.127.71) 13.569 ms core3-te0-17-0-0.faraday.ukcore.bt.net (62.6.201.166) 13.574 ms
9 195.99.127.53 (195.99.127.53) 13.551 ms 195.99.127.169 (195.99.127.169) 13.686 ms 195.99.127.53 (195.99.127.53) 13.605 ms
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
1 Blizzard (Blizzard) 0.651 ms 0.686 ms 0.740 ms
2 * * *
3 * * *
4 Blizzard (Blizzard) 10.843 ms 11.077 ms 11.199 ms
5 * * *
6 t2c3-xe-0-0-0-0.uk-lof.eu.bt.net (166.49.208.213) 13.492 ms 13.344 ms 13.336 ms
7 213.137.183.39 (213.137.183.39) 12.822 ms 13.543 ms 13.553 ms
8 core4-te0-7-0-0.faraday.ukcore.bt.net (62.6.201.168) 14.643 ms 13.225 ms 13.366 ms
9 195.99.127.53 (195.99.127.53) 13.577 ms 13.662 ms 13.714 ms
10 195.99.127.175 (195.99.127.175) 13.756 ms 13.819 ms 14.798 ms
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
HOST: Blizzard Loss% Snt Last Avg Best Wrst StDev
1. Blizzard 0.0% 10 0.6 0.6 0.5 0.7 0.1
2. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
3. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
4. Blizzard 0.0% 10 10.9 10.8 10.8 10.9 0.1
5. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
6. t2c3-xe-0-0-0-0.uk-lof.eu.bt.net 0.0% 10 13.0 13.3 12.9 14.7 0.5
7. 213.137.183.39 0.0% 10 12.8 13.0 12.8 13.6 0.2
8. core4-te0-7-0-0.faraday.ukcore.bt.net 0.0% 10 13.3 13.9 13.2 15.5 0.9
9. 195.99.127.53 0.0% 10 13.6 13.8 13.5 15.1 0.5
10. 195.99.127.175 0.0% 10 14.0 13.6 13.5 14.0 0.2
11. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
I don't know if I'm just being a pain now, but trying to collect all the data I can, you learned guys might spot something!
